Films Training Blog
Pipeline and Tools Characters
search Login Join
favorite
Development Fund
Support Blender Core Development with a monthly contribution.
theaters
The creators who share. Access production content and knowledge from the Open Movies.
code
Blender Developer Blog
Latest news and updates on Blender development.
people
Get Involved
Join the community and help with design, development, docs and more.
bar_chart
Open Data
A platform to collect and display the Blender Benchmark results.
menu_book
Blender Docs
Documentation on Blender's features, tools and API.
Blender Conference
The yearly event that brings together the Blender community in one place.
download
Get Blender
Download the latest Blender version, or try the beta!
Films
Training
Blog
Pipeline and Tools
Characters
Search
Login
Join
Documentation
Pipeline and Tools
feed Documentation Overview
Rigging keyboard_arrow_down
Pipeline Architecture keyboard_arrow_down
  1. insert_drive_file
    Spring Production Pipeline
    visibility_off
Naming Conventions keyboard_arrow_down
    File Types
    visibility_off
  2. insert_drive_file
    In-file Prefixes
    visibility_off
  3. insert_drive_file
    Examples
    visibility_off
Tools keyboard_arrow_down
    CloudRig
    visibility_off
    Blender Kitsu
    visibility_off
  3. 03
    Contact Sheet Add-on
    Free
  4. insert_drive_file
    Watchtower
    visibility_off
  5. insert_drive_file
    Blender Purge
    visibility_off
  6. insert_drive_file
    Shot Builder
    visibility_off
  7. insert_drive_file
    Media Viewer
    visibility_off
  8. insert_drive_file
    Asset Pipeline
    visibility_off
Documentation
Pipeline and Tools
Rigging
    Free
    File Types
    Free
    In-file Prefixes
    Free
    Examples
    Free
    CloudRig
    Free
    Blender Kitsu
    Free
  3. 03
    Free
    Watchtower
    Free
    Blender Purge
    Free
    Shot Builder
    Free
    Media Viewer
    Free
    Asset Pipeline
    Free
Naming Conventions
File Types
17th December 2022
Free
flag Report Problem
Published by
Francesco Siddi
Characters
Location: {project root}/lib/char/{char subfolder}/{char name}.blend
A character asset is a collection which contains shaded geometry, rigs, rigging objects such as mesh deformers and lattices. All of these are needed to give animators control over their movement and make up the final rendered representation of the character in the movie
Props
Location: {project root}/lib/prop/{prop subfolder}/{prop name}.blend
A prop in real life is a rigged, animatable object which characters interact with or can be constrained to. An environment library asset can sometimes be turned into a prop (e.g. Autumn picks up a branch from the ground and breaks it into pieces).
Environment library assets
Location: {project root}/lib/env/{env subfolder}/{env name}.blend
The building blocks needed to turn over sets and construct the movie stage. These are either static, or can be animated in a more limited way than props. Typically a larger set of them is needed with different variations, so we group them into asset library files. For example on Spring there was trees.blend, rocks.blend, etc. Each asset is in its own collection, but is also placed in a library collection that groups them together for easier linking access.
Sets
Location: {project root}/lib/set/{set subfolder}/{set name}.blend
Sets are more tricky to define, since they can differ even on a shot level. In practice they are formed by a ground plane and dressed with environment assets. They can also contain individually created assets (Spring example: riverbed.blend contained two non-library trees which were modelled and shaded uniquely in this set). Sets can be connected together to build a larger world if necessary. Sets are contained in a main collection which has sub-collections for visibility management)
Shots
Location: {project root}**/**shots**/**{sequence number}**/**{shot identifier}/{shot identifier}.{task identifier}.blend
Textures and maps
  • {project root}/lib/maps/ for general textures which are used across the entire project
  • {asset folder}/maps/ for specific textures related to an asset
Example: dresser_wood.faded.col.png
  • As for all other files, format the entire name in lowercase, separated by _ instead of spaces.
  • Textures which are specific to a prop should include the name of the prop and THEN the name (if it's a label, or tex type such as metal or wood e.g.)
  • If there's more than one type, Textures should also include the type (col, bump, nor, disp, spec) LAST in the filename (separated by a dot)
  • make sure to clean up texture file names coming from the Blender Cloud according to these conventions. Sometimes there can be a .png.png at the end or files can have an uppercase first letter.
0 Comments
Join to comment publicly.
The Creators Who Share.
Pipeline and Tools
  • Cloud Rig
  • Blender Kitsu
  • Contact Sheet Add-on
  • Blender Purge
  • Blender Cloud Services
Characters
  • Einar
  • Security Bot
  • Huginn
  • Pack Bot
Studio
  • Terms & Conditions
  • Contact
  • Remixing Music
  • Blender.org
Loading...
