In this podcast: Sarah, Hjalti, Francesco, Andy and Pablo
Hope you enjoy listening to this podcast, unfortunately Hjalti's mic is a bit lower than the rest, will check twice next time!
We plan on releasing the third episode of Caminandes on Friday 29th, two days before recording the podcast. So we decided to make the next podcast a 'Caminandes 3 Release' special. Leave your questions in comments below!
The Blender Institute Team
Here is an other question: <br> Have have you heard of or even used the sheepit-renderfarm?<br> https://www.sheepit-renderfarm.com <br> This renderfarm is free to use and works like this: <br> You render projects for other users in times your computer have the capacity. This way you earn credits. You can use this credits later to let your projects render on multiple computers. <br>There are 150 Clients rendering at the moment. CPU and GPU rendering is supported.<br> This way, I can render my projects much faster than I normally could.
Hi! Why is Ep #009 not available on the iTunes Blender Podcast channel ?
@Eduard: Should be up now! Thanks for the reminder.
OK, you're almost finished, so, are you making a Caminandes 3 credit card-sized USB? DVD? Blu-Ray? VHS? Beta-Max?
Regarding the "Breakdowner Tool" (Shift-E):
What you're probably seeing here is due to the operator properties getting saved and reused between different runs of the operator. So, the first time you use the tool after restarting Blender, it will be at 50%. Then, the next time you use it, it will initially use the last value used (e.g. 30%, 75%, or something else), and so on. If it does do anything weird, (e.g. quickly jumping from the last used to 50) it's most likely due to a conflict going on between the mouse input and the property value. I'll take a look into this to see how we can tweak this :)
@aligorith: Hey! Great to see you here and know that you listen to the podcast :D
Thanks for dropping by!
Join to leave a comment.
