  • Characters
  • Tools
  • Join
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
Training Highlights
Geometry Nodes from Scratch
Stylized Character Workflow
Training types
Training categories
Film Highlights
Singularity
In production
Wing It!
2023
Charge
2022
Sprite Fright
2021
Project Highlights
Project DogWalk
Interactive
Gold
Showcase
BCON24 Identity
Showcase
Fighting with Grease Pencil
Article
  • Wing It!
Introducing bbatch: batch file processing with Blender
bbatch is a command line tool used to find .blend files and execute a provided python script.
  • Update
  • 14 Dec 2023
  • 2 min read
Nick Alberelli
Nick Alberelli Pipeline TD
Report Problem
A very common task during production is to perform repetitive actions on multiple .blend files (fixing paths, adjusting settings, etc.). This process can be time consuming and error-prone.
After writing small ad-hoc scripts for years, today we are sharing bbatch, a command line tool used to find .blend files in a given directory and execute a provided Python script on each file. Here is a quick overview.
Simply provide bbatch with a directory and a Python script and bbatch will execute that script on all the .blends it can find within the directory structure. bbatch’s functionality is only limited by a user's imagination and Python scripting abilities. Any script that can be run by Blender’s text editor can easily be executed on a directory of .blend files via bbatch.
bbatch was developed during the production of Wing It!, an earlier iteration of this tool was Blender Purge, which was used to crawl directories and purge unused data blocks. bbatch retains the purge functionality and adds several new features, to quickly execute scripts on a directory of .blend files.
Features:
  • Automatically saves .blend files after script execution
  • Automatically detects Blender if installed on your system
  • Supports passing multiple script files
  • Supports traversing multiple directories
  • Filter only for .blend files that match a given string
  • Ships with a purge script to remove unused data-blocks from all crawled files
How does it work?
First, check out the repository at projects.blender.org.
bbatch uses Blender’s command line arguments to open a “background blender” and runs a user provided script. bbatch does not create additional save versions when saving after script execution. To use bbatch follow the instructions on the bbatch readme.
Comments are welcome!
If you have feedback or suggestions, reach out via the comments or in the Blender Studio Pipeline Issue Board. Enjoy bbatch!
Join to leave a comment.
Pipeline and Tools
  • CloudRig
  • Blender Kitsu
  • Brushstroke Tools Add-on
  • Blender Studio Extensions
Characters
  • Mikassa
  • Whale
  • Ballan Wrasse
  • Snow
Studio
  • Terms & Conditions
  • Contact
  • Remixing Music
The creators who share.
