  • Characters
  • Tools
  • Join
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
Training Highlights
Geometry Nodes from Scratch
Stylized Character Workflow
Training types
Training categories
Film Highlights
Singularity
In production
Wing It!
2023
Charge
2022
Sprite Fright
2021
Project Highlights
Project DogWalk
Interactive
Gold
Showcase
BCON24 Identity
Showcase
Fighting with Grease Pencil
Article
  • Sprite Fright
Sprite Fright: Sculpting Advice
Julien shares his tips for character sculpting in film production, and lessons learned in Sprite Fright.
  • Article
  • 14 Dec 2021
  • 7 min read
  • 2 min watch time
Julien Kaspar
Julien Kaspar 3D Artist
Report Problem
Sprite Fright is the new Blender Open Movie that was recently released on YouTube. Now it’s time to share some of the lessons that were learned during the production.
A lot of content I find online about character sculpting is following a very similar workflow. Nowadays I find that workflow very strict and outdated, especially after I followed it myself in Spring and other film productions.
So what do I mean with that?
Concepting in 3D
I still see a misconception that character design needs to be first figured out in 2D.
Only after extensive drawings and illustration work do the sculptors come in and slowly adapt the design as faithfully as possible in 3D. This is very rigid and top-down.
Drawing and painting was always much more efficient and creating variations & ideas is fast. But keep in mind that 3D sculpting is faster, more flexible and intuitive than ever! My advice is to also work on the character design in 3D as soon as possible.
The very first sculpt of the Sprite. It showed us a lot that didn't work in the design, so we changed it.
After Ricky Nierva completed his initial concepts we immediately jumped into 3D.
A couple of days of sculpting can tell you a lot about what works and what doesn’t in your 2D drawing. From there we kept bouncing back in 2D & 3D, adjusting and exploring the design until we came to the result that worked best.
Sculpting early on in Blender saves time instead of wasting it. There are of course many artists that can convey a design perfectly in 2D.
But this won’t tell for sure if it actually works in the movie.
And it's incredibly useful if the sculpts are always available to the entire team.
So we even had early shading, rigging, animation and environment exploration with the characters as soon as possible.
While the sculpting was still very early, Simon tested procedural textures on the sculpts. This then informed us on the ideal level of detail.
Sculpt for Design
This is a lesson I finally had to get hammered in.
Sculpting is primarily a design task, not a production step!
So try to avoid these common sins when presenting your sculpts:
  • A straight neutral T-pose or A-pose
  • A neutral facial expression
  • Straight, orthographic turntables or turnarounds
  • A high contrast Matacap for shading
A comparison of how I presented sculpts at the start of the production vs later on.
Your job as a sculptor is to create an appealing character design in 3D. That also means showing the design over creating a model that can efficiently be retopologized and rigged.
When the director needs to approve your work it will be unnecessarily hard if the sculpts look dead and just completely without … character.
So do yourself a favour and try to:
  • Put the arms down and relax their back
  • Add at least a subtle expression fitting to the character
  • Use soft Studio viewport shading or Eevee for lighting
  • Add subtle Ambient Occlusion & Shadows
Experiment even more to *really* sell the design and find the right direction.
If you want to take it to the next level then take a bit of time to use the Pose Brush and Transform tools in Sculpt Mode.
A character in a proper pose & expression can really help solidify the design!
These sculpts are too hard to update and maintain of course.
But don't think now: "Well why not just draw this. Sculpting it won't take too much time!?". Yes! Sculpting your designs and trying stuff out in 3D will not take too much time. And keep in mind we are a very small team. I was the only sculptor for 13 characters and we still got to do all this.
Put them into a production ready T-pose later. Only once you need to hand over the sculpts for some early rig/animation tests, layout work or the final retopology.
Design for Story
The characters don’t get created in isolation.
You need to be constantly aware of what is required of them in the storyboard.
Some characters might only be in a few shots with very little interactions.
So be aware of what your character needs to be able to do:
  • How do they move? (Animation style & level of realism)
  • Is anything stopping them from moving or acting properly? (Outfit & proportions)
  • What props are they interacting with? Are they able to?
  • What parts are seen up close? (Minimum level of detail)
There have been a few tests for each character to see if the character designs will work in planned shots.
Storyboards are often not on-model or spatially consistent.
If you are aware of that then you will spot the issues in the character designs.
Like that the Sprites will have to be visible from certain angles, or even hold hands.
With their huge caps that becomes impossible. So the story or design needs to be adjusted. The earlier this happens the better!
Work Iteratively
All of this said, the story can change a lot during your work.
So be prepared for changes!
Don’t rush ahead and start sculpting in detail before the design is approved.
I’d even say that adding detail should be done as procedurally and non-destructive as possible. So shader & geometry nodes can help a lot here.
And of course create versions! Keep old files and models around.
Just imagine feedback comes in that the sculpt you had a week ago actually worked better ... but you didn't keep it.
Ellie went through the most amount of changes. For a time we focused way too much on hear upper body & hair.
It also helps to keep the design focused.
It’s easy to rush ahead and lose yourself in the details.
But if you detail the sculpt iteratively over the entire body, it will be easier to keep the original shape-language and design in mind.
We had to learn the hard way in this production.
Lineup Consistency
For this movie we had an insane amount of characters. 13 in total. More than any other Blender Open Movie before. And most of them are main characters.
All final characters except for the chunky snail used in the night sequences.
What we repeatedly did wrong and taught us a hard truth is:
You have to work on all major characters at the same time!
To make sure the art style & designs of the characters, props & environments are consistent and work together.
Any time we focused our efforts on one character or left others behind, the whole lineup suffered. This happened to the two female characters especially.
So my advice is to regularly check & discuss the character progress not by looking at individual characters, but by comparing the entire lineup.
Even if the characters have wildly different shape language and proportions (maybe especially then), you need to compare them. They all have to belong in the same world after all.
Style Guides & Handovers
A lot of things happen during the character creation. Once you roughly have the designs approved it’s finally time to polish them.
One of the tasks tied to this are Expression and Pose tests.
These will be massively helpful, not just in making absolutely sure that your characters can perform in the movie, but also to create a style guide for the next departments or artists.
Many expressions were sculpted based on the storyboard and any necessary emotions.
At this point you will be aware of all the things that went into the design. You’ll have worked on these characters for months. The retopology, rigging, animation, shading & grooming also need to know!
So gather notes during the sculpting process and create a style guide:
  • The style in which they emote & move
  • The required deformations and stretching
  • Stylistic choices (Like fake wrinkles & shape shifting teeth)
  • Directors notes & art direction (Like shape language, style & animation)
  • Limitations (Angles to avoid and restrictions in the design)
With early sculpts as a guide these extreme expressions are easier finally to rig and animate.
Then it’s finally time to create a handover. Clean up your files. Make sure everything is ready for the next person to work on.
And give them all the important notes yourself, or preferably to the art director, or both.
If you have any more questions let me know below! I hope you got to learn something from this.
More detailed tutorials can be found in in the training section, like the Stylized Character Workflow.
Join to leave a comment.
3 comments
Dan McLaughlin
Dan McLaughlin
Dec. 15th, 2021
Julien, great tips! Couple questions relating to more detail on the workflow 1) Looks like for the sculpt test phase you use shape keys, transitioning to rigs for production. What is that lattice you're using on Ellie above, is that an add-on? 2) When you move to production, do you use the original sculpt as just a reference, or a starting point that you refine and rig? 3) Do you remesh, multires, dyntopo or ? 4) You don't bake hi->lo poly I assume? So for you guys sculpt really is design, is the movie rendered with a low poly remesh?
Julien Kaspar
Julien Kaspar
Jan. 3rd, 2022
@Dan McLaughlin Sorry for the late reply!     1: The Lattice is used on all the objects of the character and is great for adding some very simple posing & squash & stretch. This saves me the effort of adding a rig to the sculpt.    2: Yes we are using the shapes of the sculpt for the retopology. For a the layout characters in early production we might even use the lowest resolution of the sculpt and rig them instead.    3: At first remesh and dyntopo. But once the general design and shapes are approved I do a very quick retopo for multires.     4: No we don't typically bake the high poly. The subdivided retopology is typically enough to capture all the sculpted shapes. We then add detail via texturing and procedural shaders. For sculpting we rarely add that much detail.
Oscar Valverde Ramirez
Dec. 14th, 2021
Thanks for the Insight Julien, I really enjoyed the Stylized Character Workflow because of these little things that can boost a character and it's presentation when it comes to production. Cheers from Costa Rica!
Pipeline and Tools
  • CloudRig
  • Blender Kitsu
  • Brushstroke Tools Add-on
  • Blender Studio Extensions
Characters
  • Mikassa
  • Whale
  • Ballan Wrasse
  • Snow
Studio
  • Terms & Conditions
  • Contact
  • Remixing Music
The creators who share.
