On this page
Render Review
Blender Add-on to review renders from Flamenco with the Sequence Editor
Table of Contents
Installation
- Download latest release
- Launch Blender, navigate to
Edit > Preferences
selectAddons
and thenInstall
, - Navigate to the downloaded add-on and select
Install Add-on
After install you need to configure the addon in the addon preferences.
Before you get started
This addon requires a specific folder structure of the rendering pipeline. This structure is defined by Flamenco
If you have a different folder structure the addon might not work as expected.
Features
- Quickly load all versions of a shot or a whole sequence that was rendered with Flamenco in to the Sequence Editor
- Inspect EXR's of selected sequence strip with one click
- Approve render which copies data from the farm_output to the shot_frames folder
- Push a render to the edit which uses the existing .mp4 preview or creates it with ffmpeg and copies it over to the shot_preview folder with automatic versioning incrementation
- Creation of metadata.json files on approving renders and pushing renders to edit to keep track where a file came from
- Connection to
blender-kitsu
addon, that can be enabled and extends the functionality of some operators
