Skip to content
Final Render
Once the approved image sequences have been loaded into the main edit you are ready to create a final render of your film.
  1. Open your Edit .blend file
  2. Render Video as PNG Sequence
    1. Under Properties>Output Set the output directory to your_project_name/shared/editorial/deliver/frames/
    2. Set the File Format to PNG
    3. Select Render>Render Animation
  3. Render Audio
    1. Select Render>Render Audio
    2. In the Side Panel select Container .wav
    3. Set the output directory to your_project_name/shared/editorial/deliver/audio/
  4. Run Deliver script
    1. Copy the delivery.py from your_project_name/blender-studio-pipeline/film-delivery/ to the directory your_project_name/shared/editorial/deliver/
    2. Enter delivery directory `cd /your_project_name/shared/editorial/deliver/
    3. Encode audio with ./deliver.py --encode_audio audio/{name_of_audio}.wav
    4. Encode video with .deliver.py --encode_video frames/
    5. Finally .delivery.py --mux
  5. Final Render will be found in the mux directory
