On this page
Render Shot with Flamenco
Once your shots are all ready to go, you can now render a final EXR from each of your shot files.
- Open a shot file
- In the properties panel navigate to Output, and set your file format to OpenEXR with Previews Enabled
- In the properties panel navigate under Flamenco
- Select
Fetch Job Types - From the Dropdown select
Simple Blender Render - Set Render Output Directory to
your_project_name/render/ - Set Add Path Components to
3 - Finally Select
Submit to Flamenco
- Select
