Skip to content
Anim Cupboard
Anim Cupboard is a small collection of operators and tools requested by Blender Studio animators.
Features
Select Similar Curves
Location: Graph Editor -> Select -> Select Similar Curves
This will set the selection state of all selected bones' curves based on whether they match the transform channel of the active curve. For example, if the active curve is a Y Rotation curve, all Y Rotation curves will be selected, and all others de-selected.
Lock Curves
This operator lets you set the lock state of selected, un-selected or all curves.
Easy Constraints
Location: 3D Viewport -> Sidebar -> Animation -> Easy Constraints
This UI panel lets animators easily create and manage Copy Transforms constraint set-ups with a VERY minimalistic UI.
In future, other constraint types can be added as well.
