Skip to content
Render Shot with Flamenco
Once your shots are all ready to go, you can now render a final EXR from each of your shot files.
  1. Open your shot .blend file by navigating to Project > Open Shot.
  2. In the properties panel, navigate to Output and set your file format to OpenEXR with Previews enabled.
  3. In the properties panel, navigate to Flamenco:
    1. Select Fetch Job Types.
    2. From the dropdown, select Simple Blender Render.
    3. Set Render Output Directory to your_project_name/render/.
    4. Set Add Path Components to 3.
    5. Finally, select Submit to Flamenco.
