Prepare Edit
Sync Your Edit with Kitsu Server
Most productions begin with a previz or storyboard step, showing the overall direction and plan for the production. By inputting this as video strip(s) into a VSE file, you can automatically create the corresponding shots on the Kitsu Server directly from the VSE.
- If not already done, ensure your project settings are set up in Blender Kitsu Add-On Preferences.
- Navigate to
Project > New Editin the header orFile > New > Edit Fileto create a new Edit file at the pathyour_project_name/svn/edit.
- The operator provides the option to automatically create an Edit task if it doesn't already exist on your Kitsu server.
- Populate your new edit file with your previz or storyboard.
- With your strip selected, in the Blender Kitsu side panel of the VSE, select "Create Metadata Strip from Active Shot" to create a new Metadata Strip.
- Next, select “Init Active Shot” and enter the Shot and Sequence names you would like to submit to Kitsu.
- Finally, select the “Submit New Shot” button to submit this new shot to the Kitsu Server.
Repeat steps 5–7 for each shot in the sequence. Multiple Metadata Strips can be made from a single previz strip if required; adjust the shot’s timing by simply trimming the Metadata Strip in the timeline. Below is an example of a previz sequence with Metadata Strips.
