Skip to content
Import Playblast into Edit
Returning to your edit .blend file, you can now load the playblast from the shot file into the edit.
  1. Open your edit .blend file by navigating to Project > Open Edit.
Invoke Open Edit
  1. Select the Metadata Strip associated with your shot.
  2. From the Sequencer Side Panel, select Import 1 Shot Playblast.
Import Shot Playblast
  1. Select the Task Type you would like to load the playblast from and an empty channel.
  2. Your new playblast will be imported with the same timing as the corresponding metadata strip.
