Skip to content
Creating Your First Asset
The next step is to create an asset and store that information on the Kitsu Server. If you are using the Asset Pipeline Add-On, see the Asset Pipeline Guide.
  1. If you haven't already, ensure your project settings are set up: Blender Kitsu Add-On Preferences.
  2. Follow the Kitsu New Asset Guide to create your asset on the Kitsu Server.
  3. Navigate to Project > New Asset in the header or File > New > Asset File to create a new asset file.
Invoke New Asset
  1. Select an Asset Type and Asset in the Operator Pop-Up. Your asset file will open.
Draw New Asset
  1. Under the Kitsu > Context > Set Asset sub-panel:
    • Collection is set to the asset's parent collection.
    • Run the Set Kitsu Asset operator to send the current filepath and selected collection to the Kitsu Server.
Set Kitsu Asset
  • You should now see the filepath and collection under the asset's metadata on Kitsu.
Kitsu Asset Metadata
  1. Your new Asset file will be saved to your_project_name/svn/pro/assets/{asset_type}/{asset_name}/{asset_name}.blend.
