On this page
Cache Manager
cache-Manager is a Blender Add-on to streamline the alembic cache workflow of assets.
Table of Contents
Disclaimer
This addon is not used in the production of the Blender-Studio anymore and is not maintained actively.
Installation
- Download latest release
- Launch Blender, navigate to
Edit > Preferences
selectAddons
and thenInstall
, - Navigate to the downloaded add-on and select
Install Add-on
How to get started
After installing the addon you need to setup the addon preferences.
Root Cache Directory: Root directory in which the caches will be exported. Will create subfolders during export
Features
The goal of this add-on was:
- Automate export of Alembic caches on a collection basis by tagging them as a "cache collection"
- Export of a cacheconfig.json that holds metadata and contains animation values of properties that are not supported by Blender's implementation of Alembic.
- Automate import of the Alembic cache on top of existing assets by using the Mesh Sequence Cache Modifier and Transform Cache Constraint
- Being able to process the cacheconfig.json
- Link in all assets from their source file based on metadata in the cacheconfig.json
- Applying additional animation which is stored in the cacheconfig.json
You can control if modifiers should be disabled / enabled during import /export:
- enable disable modifiers for cache with suffix in modifier name
- modifier_name.cacheoff -> modifier off for export on for import
- modifier_name.cacheon -> modifier on for export off for import
